RG-ES05G
Kalite, kullanım kolaylığı ve maliyet etkinliğinin mükemmel birleşimi
Ruijie Reyee Serisi Plastik Anahtar, küçük işletmeler, küçük ölçekli gözetleme ve küçük ofis/ev ofis (SOHO) için özel olarak tasarlanmış bir masaüstü anahtar olup küçük işletme müşterilerinin ağ ihtiyaçlarını karşılamak için toplamda 4 farklı modelden meydana gelir. Bu anahtarlar, hızlı uygulamaya koyma deneyimi sunmak için ağ kameraları, yazıcılar, Bilgisayarlar, vb. Gibi çeşitli terminaller ile uyumluluk, sıfır yapılandırma ve tak-çalıştır (plug and play) özelliklerine sahiptir.
Exquisite Design
The matte-finish diamond pattern design with honeycomb heat dissipation holes at the bottom ensures effective heat dissipation while offering an exquisite appearance. The embedded foot pads and hidden hanging hole design also provide ease of use for the users.
Enterprise-grade Quality
The high-quality 8-core network cable and enterprise-grade components ensure no packet loss or lagging for data transmission.
Rigorous Testing
Plug and Play & Energy Saving
Self-adaptive feature is supported for the network ports. With zero configuration, the device can operate instantly after plugging in. The energy saving feature enables the non-operating ports to automatically reduce power consumption, and the fanless design also enables noiseless operation.
The series is an ideal choice for surveillance, small enterprises, school dormitories, SOHO, and domestic use.
RG- ES05G |
5 10/100/1000M Base-T ports |
RG- ES08G |
8 10/100/1000M Base-T ports |
Model | RG-ES05G | RG-ES08G |
Ports | 5 10/100/1000M Base-T ports | 8 10/100/1000M Base-T ports |
Operating mode | Half-duplex, full-duplex, auto-negotiation mode Support auto MDI/MDIX |
Backplane bandwidth | 10Gbps | 16Gbps |
Packet forwarding rate | 10Mbps:14880pps 100Mbps:148800pps 1000Mbps:1488000pps | 10Mbps:14880pps 100Mbps:148800pps 1000Mbps:1488000pps |
MAC address | 2K | 2K |
Power supply | External, DC 5.0V / 600mA | External, DC 9.0V / 600mA |
Maximum power consumption | ≤2.5W | ≤2.5W |
Fan | Fanless | Fanless |
Dimensions | 108.1mm*64mm*24.8mm | 144mm*85mm*23mm |
Temperature | Operating temperature: 0 ℃ ~ 40 ℃ Storage temperature: -40 ℃ ~ 70 ℃ |
Humidity | Operating humidity: 10% ~ 90% RH Storage humidity: 5% ~ 95% RH |
- Installation Guide
- RG-ES05G, ES08G Kullanıcı El Kitabı (V1.0) 2023-10-23
- Implementation Cookbook
- Product Datasheet
- PoC Guide
- Reyee Switch PoC Guide V1.0-TR 2021-11-03
