Background
Delta-Opti is a leading European distributor specializing in video surveillance, security, and automation solutions. With more than 35 years of experience, the company imports and supplies around 10,000 products across Europe. Its central warehouse in Poznań plays a vital role in daily operations, processing hundreds of orders every day. A stable and high-performance network is essential to support fast and accurate distribution.
Requirement
Delta-Opti needed a network that could support:
• Stable Wi-Fi for smooth terminal and order processing.
• Strong roaming and full coverage across a 2,000 m² warehouse with metal racks.
• Secure network segmentation to separate business and personal devices.
• Centralized management for easy maintenance and quick troubleshooting.
The Solution
To meet Delta-Opti’s operational needs, Ruijie designed a simple yet powerful network system.
How It Helped
• Network Upgrade: RG-EG310GH-E gateway + RG-NBS3300 Multi-Gigabit PoE switches + 12 RG-RAP73Pro APs for reliable, high-bandwidth coverage.
• Efficiency & Stability: Full 2,000 m² coverage, enhanced roaming effect for Zebra terminals, no dead zones.
• High Bandwidth & Low Latency: Multi-Gigabit access + 10G uplinks ensure stable video and WMS data.
• Secure Segmentation: VLAN isolates terminals, cameras, and employee devices.
• Centralized Management: Ruijie Cloud enables unified management and monitoring.
What the Client Says
The upgrade has brought clear benefits to Delta-Opti’s daily workflow. The network now supports seamless operations across the warehouse, helping staff process orders faster and with greater accuracy. This reliable connectivity strengthens the entire supply chain, from inventory management to final dispatch.
”Our main business is the import and distribution of goods across Europe. At our key warehouse handling hundreds of daily orders, we built a modern network with Ruijie Networks, providing stable Wi-Fi for 28 Zebra terminals, employee devices, and video surveillance across 2,000 m².
Investing in Ruijie Networks infrastructure has transformed our network from a potential bottleneck into a core pillar of our logistics operations, directly supporting fast, reliable, and efficient distribution across Europe.”
— IT Manager, Delta-Opti
Product List
• Router: 1 × RG-EG310GH-E
• Switches: 1 x RG-NBS3300-16MG2XS-P and 1 x RG-NBS3300-8MG2XS-P
• Wireless Access Points: 12 × RG-RAP73Pro
Find Your Perfect Access Point
Want to see how the RG-RAP73Pro compares with other Reyee access points? Our Reyee Product Comparison tool lets you see all models side-by-side and focus on the differences that matter most to you.
